HOW TO FIT ENGINE BARS TO A ZED
- london calling
Any sensible suggestions,as I'm asking on behalf of someone else.
Jack
i think the the small casing huggeing ones look ok, but as piford says , long engine mounting bolt is not long enough for them , side tear drop nut and bolts are a bugger to get back on, and if you have the original exhaust on near impossible.
patience patience luck and more patience needed.
but if you drop the bike worth it
top tip drill the tear drop nut on the bottom edge 3mm and sit em on an electricians srewdriver before trying to locate them saves all that figglin about and cursin when the thread wont engage
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
