z1100 forks
z1r
z1100 forks
#1 PostAuthor: z1r » Fri Mar 28, 2008 10:59 am
got a z1100 with forks that have a valve or somthig at front bottom of legs, anybody know what its for.
rickman CRR
#2 PostAuthor: rickman CRR » Fri Mar 28, 2008 7:41 pm
maybe anti-dive unit as fitted to gpz models?
z1r
#3 PostAuthor: z1r » Sat Mar 29, 2008 6:37 am
can it be removed
FER
Auld Heedyun
#4 PostAuthor: FER » Sat Mar 29, 2008 9:30 am
You can take antidive unit off and fit a blanking plate .
fer
z1r
#5 PostAuthor: z1r » Sat Mar 29, 2008 6:39 pm
thanks for answer, will it not affect the working of the forks.
#6 PostAuthor: Pigford » Sat Mar 29, 2008 9:46 pm
Forks will be same, all the anti-dive does, is increase the damping when braking.......
So you may get a bit more dive under braking.....
It's a bit of a gimmick, coz it hasn't been on production bikes for years :wink:
Pasc
#7 PostAuthor: Pasc » Sun Mar 30, 2008 8:14 am
If you blank off the anti dives using a plate you will need to link the anti dive oil holes with a channel milled into the blank off plate or fork oil will not flow the correct route and you will have a rock hard front end. Might have a cad drawing of the plates somewhere.
Like these
