Pigford's Red Zed - long term projext XYZ
Mikey, going a bit slow at the mo
Doing a bit of engine work at present, just got hold of some better (1045) barrels & Wiseco pistons, and got some .395 cams that need collected from Steve (Romeo) Debben
I have a decent rolling chassis now and have just got the V5 (R reg) back from the Misnistry of DVLA
Got most of the other stuff in boxes (Dyna S, new cam chain, rollers & guides) and a couple of exhausts to choose from
Then it'll be a wiring job, as the looms a bit knackered
Hope to get me RedZed on the road for Summer
Know what you mean by knackerd loom should see the loom on me mk2
no idiot lights suzuki ignition switch behind left side panel most connections just twisted together
and the rest of it i just binned. think me brothers gonna get a call hes an electrical genius
Well, actually been out in the garage this morning & finally split the engine
All went smoothly, all the bolts came out OK
Got the crank out at last so I can fit the new cam chain
The old camcahin is the lower one and when next to eachother the stretch is visible...
Got me new stuff ready for installation..... cheers Jeff
....along with the Wiseco & barrels... cheers Chrisu...
...and the other SPECIAL stuff..... cheers Steve Romeo D.....
- RALPHARAMA
Looking at the bottom pic ... best you get that crank welded!
Ralph Ferrand
- z1bnackerkwacker
- z1bnackerkwacker
Finally got me crank welded...
The workshop Engineer at my work did it for me.... used a low alloy, hi-carbon rod or sumink
Cost me a 4-pack of Stella Artois
I've ground the weld back and cleaned it up. Fitted me new cam chain & with the help of me lad its back in the casing
Gonna get a windage tray from Steve 'Romeo' debben next week and hope to get cases back together by next weekend
- london calling
- paul doran
- Dark Skies
