Guys,
had a call from the shop thats trimming my valve stems. They said to me the valve springs were in the wrong way around, but I can't recollect anything in my manual which says there is a right or wrong way of fitting them. Apparently they are progressively wound and that this means there is correct end to fit against the head??
Are they correct?
Which end up for valve springs - had a call from the Shop... Doh!
