Anyone used the repro Z1 wiring looms on a Z900? Was wondering if the change of wiring run from the RH side cover on Z1 to LH on the Z900 causes any problems?
John
reproduction wiring looms
cra-z1
John, I believe you would have to modify the Z1 series loom significantly, to make it work. The difference is mainly in getting the extra Z900 fuses in the circuit, hence getting the wires to the position of the original fuse box. It could be made to work by ingnoring these fuse or installing them individually elsewhere.
Read BigFluff comments at "Z thou A1 Loom " (Bike Help a few pages back)*.
RegardZ
RegardZ
