Spark Plugs
Spark Plugs
I know Nippon Denso W24ES-U are currently the plug of choice, does it make any difference if you are running Dyna Coils and ignition?
Also is it worth paying extra for the W24ES-ZU iridium plugs ?
- RALPHARAMA
Coils shouldn't make any differnce to plug heat value to the best of my knowledge.
In my opinion there is a lot of cock talked about so say whoopy shit plugs. Over the years I have tried fancy pants plugs and I have never had any discernable change in power from one make of plug to another, Some plugs, like modern NGKs, liedown with their legs in the air when shown the vaguest hint of moisture, whereas the Nippon Densos I took from my oil drinking monster were so covered in clagg, it's a miricle they worked at all. Maybe on a really uber highly tuned engine, the ultra expensive plugs might make a couple of hundredths difference off the line, but it is my belief that on old engine like ours it is only a plaecebo effect and having spent silly money you don't want to admit to your mates you've been shagged over
I think these fancy plugs are a bit like spoilers on cars - on a formula one car you need a wing to keep the arse end on the ground, but an Astra ... I don't think so
Ralph Ferrand
- london calling
Any fine tip plug is a GOOD idea.
Better spark - burn of fuel = more economy & power, even if its hard to detect.
Less chance of fouling plugs too - less energy needed to make spark.
I run all me Zeds with Dyna kit, so I believe in have the WHOLE ignition system as good as poss, even if just for the placebo effect
I run the posh Denso iridium plugs (?40 a set
) along with Dyna 2000, Dyna 2.2 coils & Taylor silicon leads.... ahhhhhhhhhh
- RALPHARAMA
I'll stick with the ?4 a set ones and buy my self another 4 tank fulls of petrol!
When someone shows me a set of real dyno prints of a regular quid a piece plugs and another on the same bike showing a significant increase for these so called wonder plugs I'll go out and by a box full.
Ralph Ferrand
- RALPHARAMA
The only thing that would make a significant difference to the speed and economy of my bike, would be for me to loose the odd stone or three!
Hmm, think that same applies in this camp
Ralph Ferrand
