Number plate size?
justin taylor
Number plate size?
#1 PostAuthor: justin taylor » Wed Feb 20, 2008 1:06 pm
Does anyone know the correct size number plate for my 1975 Z1B?I have been told it would have been pressed alloy,9"by6" with 2.5" letters.Is this right?Cheers.
Steve S
#2 PostAuthor: Steve S » Wed Feb 20, 2008 1:24 pm
Sounds about right,just had one made for my Z1A,will measure it to check the sizes if you like?
justin taylor
#3 PostAuthor: justin taylor » Wed Feb 20, 2008 2:10 pm
Yes please Steve.
Steve S
#4 PostAuthor: Steve S » Wed Feb 20, 2008 5:02 pm
Justin, the measurements of my plate are 9.5 inches x 6.5 inches and the letters are 2.5 x 1.75 inches, guess this is regulation size, had mine made by Framptons,(just google) though I wouldn,t recomend them as the first one they sent was not up to scratch although in fact it was actually scratched! and covered with overspray!! :( second attempt was better.
Have seen Tippers plates and they are good, though a little more expensive :roll:
hope this helps. :D
Keefleaf
#5 PostAuthor: Keefleaf » Thu Feb 21, 2008 12:33 am
Years ago I got pulled up in Chertsey by P.C.Plod/Alexi Sayle lookalike?
"Do you know why I`ve stopped you?
"No?"
"your number plate should be....X"xY"
The letters on your number plate should be.....so and so x so and so
"oh?"
Any way if your in doubt,ask P.C.Plod.
RALPHARAMA
#6 PostAuthor: RALPHARAMA » Thu Feb 21, 2008 7:45 am
I believe that pre 1973 was when you could have the non yellow plates.
Here's a link re sizes etc -
http://www.newreg.co.uk/services/acryli ... late_rules
Ralph Ferrand
phil churchett
#7 PostAuthor: phil churchett » Thu Feb 21, 2008 8:02 pm
Justin, put on the smallest plate you can :D
