Guys,
Went to go out on the Z1B on Saturday and when pushed the starter motor it seem to spin but did not turn the engine. Even in gear did not turn the engine over. Reverted to the trusty kick start.
Before  I remove the tanks, carbs and the starter motor and side casing any experinace what the issue could be.
Z1B starter motor
- wheelysteve
That's cos you fitted all that fancy heavy new paintwork. You should sell that to me and put the original stuff back on
Seriously, if you need a hand with anything, give me a shout.
(I've got some proper size hammers in the garage)
Steve
Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
						1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
if it noisy suspect starter clutch/ rollers, if its not rotor/clutch spinning on the crank which cant be good cos are they not keyed ?
									Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- SVENLEATHER
- SVENLEATHER
