Z1B starter motor
SVENLEATHER
Z1B starter motor
#1 PostAuthor: SVENLEATHER » Mon Feb 06, 2017 11:59 am
Guys,
Went to go out on the Z1B on Saturday and when pushed the starter motor it seem to spin but did not turn the engine. Even in gear did not turn the engine over. Reverted to the trusty kick start.
Before I remove the tanks, carbs and the starter motor and side casing any experinace what the issue could be.
#2 PostAuthor: z1bman » Mon Feb 06, 2017 12:51 pm
starter clutch or rotor has come loose
wheelysteve
#3 PostAuthor: wheelysteve » Mon Feb 06, 2017 1:33 pm
That's cos you fitted all that fancy heavy new paintwork. You should sell that to me and put the original stuff back on :D
Seriously, if you need a hand with anything, give me a shout.
(I've got some proper size hammers in the garage)
Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
KeithZ1R
#4 PostAuthor: KeithZ1R » Mon Feb 06, 2017 4:30 pm
if it noisy suspect starter clutch/ rollers, if its not rotor/clutch spinning on the crank which cant be good cos are they not keyed ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#5 PostAuthor: chrisu » Mon Feb 06, 2017 4:39 pm
just the stator side cover needs to come off.
SVENLEATHER
#6 PostAuthor: SVENLEATHER » Tue Feb 07, 2017 1:29 am
Cheers chaps, will try and get the spanners out this weekend . Will let you know the findings
#7 PostAuthor: chrisu » Tue Feb 07, 2017 7:22 am
Think I've got an unused starter clutch repair kit. Message me if that's the fault
SVENLEATHER
#8 PostAuthor: SVENLEATHER » Sat Feb 11, 2017 12:59 pm
Guys
Keith looks like you were right rotor spinning on crank. Now the question is how to fix it. The bolt holding it on was loose so after 10 years I guess it's started to slip.
Any ideas?
