Piston rings
Piston rings
Hi guys, anyone know how to release the piston rings from their grooves, I have number 1 piston the the top two rings are stuck fast, cannot even get a feeler gauge in the groove, is there owt I could soak them in or any other method. Cheers.
Hi David,Sounds like you are having a bit of fun with this build,are the rings scrap and pistons out of engine.If so Red x might be worth a go,its supposed to free off gummed up rings.. if still in engine try rags soaked in the stuff,Good luck Paul J
