Unitrak Cams
				Julian_Boolean
Unitrak Cams
In my ongoing rebuild I have noticed that the cams in my uni head have R3 stamped into the inlet cam and R2 stamped into the exhaust cam, is this normal for Uni cams?
				Julian_Boolean
				Julian_Boolean
Found this
http://oldschoolperformance.com/forum/v ... 656d1398ea
With comments from Zed1015 on it, now I've no idea what cams I have, and my bike might have had the cams round the wrong way as the R2 cam was definitely the exhaust cam and R3 the inlet. Cam sprockets have Z1100A on them by the way.
Is there an easy way to tell an inlet cam from an exhaust cam?
I'll measure my lobes, but I'm not sure I've got anthing accurate enough to tell the difference of 0.05mm in overall cam height.
Exhaust cam has a blank raised section instead of the tacho worm.
Inlet and exhaust cams can be swapped over if they are the same profile or maybe the exhaust cam from another model has a higher lift you could use it on the inlet.
My uni cam sprockets are Z1100B.
My uni cams are 1983 but judging by the OSP thread it's probable that later cams and sprockets have different markings but the spec is the same.
All the info for lift etc is in my posts in the OSP thread so it should be easy enough to see if yours are uni.
				Julian_Boolean
Cam sprockets actually say Z1100B, I was wrong when I said they had a B
The cams look identical apart from inlet is stamped R3 and exhaust R2, all lobes are 37.8 mm, both cams have what look like blanks for the tacho drive to the right of the sprocket.
CMSNL shows exhaust and inlet cams on Unitraks and Z1100Rs having the same part no.
You can tell the inlet from the exhaust by the position of the sprocket.
Julian_Boolean wrote:The cams look identical apart from inlet is stamped R3 and exhaust R2, all lobes are 37.8 mm, both cams have what look like blanks for the tacho drive to the right of the sprocket.
Yes! both cams have the same profile with any slight height difference down to factory tolerances and wear.
37.8mm is Uni spec cams then.
1100R uses the uni engine.
Cam sprockets are both the same with different positions for in and ex.
