Choke Plunger
nicomkii
Choke Plunger
#1 PostAuthor: nicomkii » Thu Dec 01, 2016 2:12 am
No.3 plug is fouling on rich fuel mix. Eliminated everything else that I know of and even went to the extent of changing all avail components from No.3 to No.4 ( hoping the issue would transfer and at least not have to remove the bloody things with original airbox all the time !!! ) but the issue stayed on No.3.
I'm thinking it has to be the choke plunger, so going to strip the whole units down to give a clean out and see what the go is.
With the plungers do they stuff up, as in need replacing often ? I'd rather have parts on hand so the carbs aren't laying in pieces for weeks. A quick look makes it a difficult search for plungers in any case.
Nico
#2 PostAuthor: PAULJAC47 » Thu Dec 01, 2016 8:26 am
Swap the plungers,there is a seat on the bottom of them that goes hard,you cant replace the seal,look for another one if the problem transfers,common problem,use a Gunson colourtune to prove! Paul j
nicomkii
#3 PostAuthor: nicomkii » Fri Dec 02, 2016 12:56 pm
Any kits that have these included or is it a seperate item ? Got a good seal place down here that can supply almost anything if given original measurements and usually at 1/8th of the cost !!!
Also is there a link to a thread that deals with complete strip and rebuild of the carbs ??
Nico
#4 PostAuthor: PAULJAC47 » Fri Dec 02, 2016 1:03 pm
As i said you cant replace its pressed into the bottom of the brass plunger,Google, wired George he has some good tips on his site,also the Gs resources has some good info..Paul J
nicomkii
#5 PostAuthor: nicomkii » Sat Dec 03, 2016 12:28 pm
Misread that in a hazy blur, I've pulled the carbs apart and and given them a clean out. Swapped the suspect plunger from No.3 to No. 4 so if it does transfer I should be able to change out the plunger in situ.
Nico
