Braze or weld?
Braze or weld?
I'm looking to stiffen my mkII frame and noticed that Sanctuary appear to braze rather than weld. Does one method have an advantage over the other, such as less prone to cracking?
12/78 Z1000 A3A frame running 1980 C3 Police
If done correctly weld should not crack, this is usually a result of using too much heat, the wrong method (wrong gas mix) or not normalising the joint afterwards.
It's best to use oxt/acet or tig if you can.
Bronze welding is more flexible and doesn't affect the parent metal so any changes can easily be reversed in the future.
The preferable choice would be Bronze weld.
Users browsing this forum: Google [Bot] and 11 guests
