Oil capacity with Oil Cooler Fitted
Is the oil capacity on my Z1000 any more with an oil cooler fitted ie should I be filling with more oil than standard quoted amounts ?
Oil capacity with oil cooler
Thanks zed1015 - Pipes enter/leave cooler at bottom - Should I still need to drain oil from cooler at oil change and if so how is this done ? Cheers
Re: Oil capacity with oil cooler
AlanB wrote: Should I still need to drain oil from cooler at oil change and if so how is this done ? Cheers
Just drain the oil as normal from the sump.
With the hoses at the bottom the oil won't sit in the cooler at standstill.
It will drain back to the sump on it's own so no need to drain it separately.
Users browsing this forum: Google [Bot] and 18 guests
