Oil Cooler fitting
- steve bowdler
bit of an update to this.
I'm putting a 13 row cooler on my Z1R and bought one with the 'standard bracket.
Yes it was too low and fouled the tacho cable. I've made a plate with a 50mm offset to shift the cooler up by 50mm from the existing holes. Works a treat and hidden by the cooler so you don't see it.
Oil lines in from the top. Might have to change my Z1 now.....
- Fred the Zed
chrisu wrote:bit of an update to this.
That's essentially what my plan is too. Thanks for the update.
Fred
Paid Up Member
