brakes - should I tackle this work
the front brake lever went solid, the bike wouldn't stop, then eventually it became free again. The front brake is now binding I have twin discs on my Z1,one is still free,the question is are the brake parts still available ie service kits for original calipers and possibly the same for the master cylinder.Is this a job that can be tackled by an amature.
- Davy Doherty
cheers Pigford and Davy I've been looking on zpower,i did,nt realise how much was available i dont want to start the job and then be left waiting for parts if dont get all the relavant parts I will probally ring them and see what they advise.As for patience and engineering prowess,i have a garage and a bike ramp all the tools "i think" and a sister who works in casualty, how hard can it be?
- Davy Doherty
IF ITS A Z900 I HAVE ALL THE PARTS YOU NEED EVEN CALIPERSQuote: from rimmer on 8:48 pm on Oct. 2, 2006
- london calling
Rimmer,don't forget to get some red rubber grease for the new seals as this will make the job easier.I use ROCK OIL but there are many other makes available.
It will be much easier to pump out the caliper pistons whilst your calipers are still connected to the master cylinder.Hydraulic pressure is much better than using an airline,especially if your pistons are seized/binding.
Avoid getting any copper grease on the rubber seals,boots,etc as it makes them swell up.
- rickman CRR
rimmer was a nick name from when i used to work a way as a shopfitter,but thats another story,Ive taken off the calipers, i,m going to order 2no repair kits from z power and i will need 1 new piston, but we have also found that plunger that the lever pushes into the master cylinder is snapped i need a repair kit but i dont know if the one i have is a 5/8 double or not what is the measurement of? they do a repair kit for the standard type but whats the difference
- rickman CRR
