Cracked Clutch Spring Plate
Cajones13
#1 PostAuthor: Cajones13 » Thu Nov 03, 2016 9:56 am
Popped the clutch cover today and spotted the outside centre has a webbing of fine cracks. They were not visible from the inside / push rod side, so not yet right through.
Has anyone else encountered this?
The only replacements I have found so far have been complete Z1000 J clutches for around $600 to 800AUD.
Has anyone tried welding one up?
12/78 Z1000 A3A frame running 1980 C3 Police
#2 PostAuthor: zed1015 » Thu Nov 03, 2016 10:45 am
Seen a few with what appear to be surface cracks like that (most likely casting fissures that have been there from new ) but never seen one fail and the pressure from the clutch mushroom is on a wider radius where the plate is much thicker too.
I wouldn't worry about it.
Cajones13
Reassuring!
#3 PostAuthor: Cajones13 » Thu Nov 03, 2016 10:51 am
zed1015 wrote:Seen a few with surface cracks like that (most likely been there from new) but never seen one fail and the pressure from the clutch mushroom is on a wider radius where the plate is much thicker too.
Thanks for that. I'm going to be putting an APE heavy duty clutch kit in and was a little worried the stronger springs might cause a failure.
#4 PostAuthor: warren3200gt » Thu Nov 03, 2016 4:02 pm
You could always JB Weld a disc in there. That would stop them spreading any further if your worried.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Cajones13
Good idea
#5 PostAuthor: Cajones13 » Thu Nov 03, 2016 11:40 pm
warren3200gt wrote:You could always JB Weld a disc in there. That would stop them spreading any further if your worried.
I might JB a stainless washer in for peace of mind I think. Tks
#6 PostAuthor: z1bman » Fri Nov 04, 2016 12:01 am
push rod length too long or clutch not adjusted correctly
Re: Good idea
#7 PostAuthor: zed1015 » Fri Nov 04, 2016 12:20 am
Gluing a washer to it won't do a thing except wreck the motor when it drops off.
I wouldn't use any chemical metal anywhere near the inside of the motor.
It's a BODGE and would be as effective as putting a plaster over a bullet wound.
That pressure plate won't fail.
We bore out that entire centre section when doing a rack and pinion clutch release conversion with no issues or loss of rigidity.
Cajones13
Re: Good idea
#8 PostAuthor: Cajones13 » Fri Nov 04, 2016 3:30 am
In that case I will relax and stop making problems for myself! Tks
Users browsing this forum: Google [Bot] and 15 guests
