How I've come to own a modified Z1000J and it's refurb
Re: Z1000j
1962royp wrote:Its a Unitrac then
I changed an engine no last year no probs at all.
Not even a letter
You were lucky.
Typical DVLA.
Pot luck whether you get a jobsworth when you send in the V5.
They introduced this policy to stop people putting big engines in smart cars to avoid Londons congestion charges.
As with all things DVLA it isn't specific to low emission vehicles so mucks up everyone else too.
Had to do it a couple of times now with a letter from the testing station confirming the new engine number and capacity.
No big deal really but just another thing that can delay getting the V5 back if you forget or aren't lucky.
Re: Z1000j
1962royp wrote:I taxed and Mot tested mine before i changed the number on the log book plus the reg doc was in my name already.
Twice I've sent V5's off that were already in my name (owned the bikes for years) and they sent them back wanting proof of engine change from a garage.
Like I said, sounds like you got lucky.
Typical inconsistent DVLA service.
Julian_Boolean
Julian_Boolean
The 4 outer head nuts need copper washers as these need to seal against the head because the 4 outer studs are also situated in the head feed oil galleries.
The other 8 are steel from the factory but most of us go copper for the lot as it gives consistent torque settings.
Make sure you anneal any new copper washers before fitting as they are hardened due to the stamping process.
Heat and leave to cool or heat and quench, it makes no difference but quenching removes the oxides and leaves the washers nice and clean.
Julian_Boolean
I have used those large yogurt pots cut down with cable ties round them. They have a ready made lip to the top to butt the bottom of the cylinder sleeves.
Dont loctite the cam cap bolts they will self lock as they are, and its not a case of them coming unscrewed. Normally you cant get the bastards out without taking the thread in the head with them!!
Take a really good look at the bolts with a magnifying glass and see if any are 'waist-ing' where the thread meets the plain shank. They are available although expensive and they are high tensile though you would not know it looking at some of them.
Julian_Boolean
Not much progress this week, I've been cleaning the old gasket from the bottom of the barrel, which is boring and time consuming.
Contacted a local machine shop about repairing the threads but he was so vague on the phone that I won't be using him, a colleague used him for some work on a Lambretta and confirmed he was unable to do the work in the timescale that he gave.
Probably take it to Chris at Grumpy 1260 (as suggested by RobW) but I can't get over there until next Saturday, so I'll give Chris a call on Monday.
Julian_Boolean
Julian_Boolean
Today I failed to get the barrel back on, so the helpful RobW popped round and helped me take the engine out so I could get the barrels put back on, Rob looked at the scoring in my barrel and said it needs reboring (I was in denial about this) so 1170 here we come, as this will be cheaper than Kawasaki oversize pistons and rings, unless someone knows a cheap source of 1mm oversize Unitrak pistons and rings.
