Inlet rubbers
needaz1100r
Inlet rubbers
#1 PostAuthor: needaz1100r » Thu Oct 06, 2016 6:28 pm
Could somebody with some kicking around please measure the fixing hole centres on a Z650, a Z1/900/1000 and aZ1000J.
Thanks in advance.
Mark.
#2 PostAuthor: Al » Thu Oct 06, 2016 6:48 pm
58mm centres for a J type.
#3 PostAuthor: zed1015 » Thu Oct 06, 2016 9:52 pm
zorded wrote:58mm centres for a J type.
And all the others are the same centres too.
needaz1100r
#4 PostAuthor: needaz1100r » Thu Oct 06, 2016 10:42 pm
Thanks Guys, that was the information I needed, but not the answer I wanted.
GS1000 are 68mm an a f**k sight more expensive.
Mark.
markz9
gs carb rubbers
#5 PostAuthor: markz9 » Fri Oct 07, 2016 9:56 am
what ones do you need I have quite a lot of spare standard size floating around at home
needaz1100r
Re: gs carb rubbers
#6 PostAuthor: needaz1100r » Fri Oct 07, 2016 11:18 am
markz9 wrote:what ones do you need I have quite a lot of spare standard size floating around at home
Hi Mak,
I need a set of early GS1000 ones, ie for the 26 or 28mm slide mikunis, not the later CVs.
Kawasaki ones aren't going to fit I now know.
Mick Znone will be along shortly to berate me for this being about a GS.
:D
Mark.
#7 PostAuthor: PAULJAC47 » Fri Oct 07, 2016 3:20 pm
No he wont he is still sulking since the Brexit "debate"
markz9
Gs carb rubbers
#8 PostAuthor: markz9 » Fri Oct 07, 2016 6:03 pm
Ok I am sure I have some do you need all four and are you going to Stafford bike show I am up there for weekend
z900a4 n20, z1000a1, zx10r, gs1000 Yoshi, gsxr750 & 7/1200 slabby race bikes, rgv250, dt250mx, 350cc New Hudson & Rickman
needaz1100r
Re: Gs carb rubbers
#9 PostAuthor: needaz1100r » Sat Oct 08, 2016 1:48 pm
markz9 wrote:Ok I am sure I have some do you need all four and are you going to Stafford bike show I am up there for weekend
That would be bloody brilliant matey, yes I need all 4, my bike had oversize rubbers for flatslides.
I am hoping to get up there, but if I can't I know a few that are.
If you PM me your mobile I'll let you know.
Thanks again.
Mark.
Users browsing this forum: Bing [Bot] and 15 guests
