can anybody help
gpzer
can anybody help
#1 PostAuthor: gpzer » Thu Oct 06, 2016 11:27 am
my gpz1100b2 is running really bad.Bike is dropping revs and spluttering as if fuel starved and having to drop it down a gear to stop it stalling ,then power will kick back in and then drop off again.ive had bike in local bike shop for last 2 weeks they've swopped ecu module, that didn't solve it and been through all obvious fuel and electrical checks.i still have original dfi unit on bike which were totally cleaned and overhauled about 18 months ago.was wanting to go to Staffordshire show on it this month.i was wanting to know if any members or if anybody knows contact numbers of any old kawa gurus in Yorkshire area who could help getting it sorted.many thanks dave.
GPZ1100 B2 OWNER
#2 PostAuthor: Pigford » Thu Oct 06, 2016 11:53 am
Assume you've double checked for corroded/loose contacts throughout the DFI wiring system :?:
#3 PostAuthor: z1bman » Thu Oct 06, 2016 3:20 pm
is the green light flashing on the ecu when the bike is running ?
Mr Bump
#4 PostAuthor: Mr Bump » Fri Oct 07, 2016 7:41 am
Did yr bike garage check fuel pressure? A mate of mine recently sorted out a z1000h running rough - that turned out to be the fuel pressure regulator.
Also, possibly, i run a b2 on carbs and have had the fuel tap partially block up in the past.
Just a suggestion, but it might match yr symptoms.
Olly
Lemmy
gpzer
can anybody help
#5 PostAuthor: gpzer » Fri Oct 07, 2016 1:00 pm
thanks for replies ,now id like to find somebody local to york that could check these suggestions out.if anybody knows of anyone,thanks :)
GPZ1100 B2 OWNER
#6 PostAuthor: chrisu » Fri Oct 07, 2016 1:55 pm
any decent garage should have a fuel pressure gauge
harri183
#7 PostAuthor: harri183 » Fri Oct 07, 2016 2:52 pm
Theres a guy I have used once in murton York, a one man band in a small unit. Seemed to know his stuff and had an old z650 in he was re-building only used him for a tyre change on the Zed but after every one else had a go and gave up he had it done in 5 min and only charged a fiver.
gpzer
can anyone help
#8 PostAuthor: gpzer » Sat Oct 08, 2016 9:42 am
thanks for all help, ive got bike booked in with alan at asl at murton so hopefully get sorted.cheers dave
GPZ1100 B2 OWNER
