Hello all,
can anyone give me some info about fitting a Z1000 engine into a Z650 frame as regards checking valve clearances? I've had to tilt the engine forward to clear the swinging arm so the rear end is raised by about 1/2" but could be jiggled a bit as the engine plates haven't been made yet. The side lugs for the lower engine mounts on the engine are currently preventing lowering the engine any more but I'm not sure about trimming them as it might weaken the mountings.
Cheers, MikeJ
Fitting Z1000A engine into Z650 frame
Too much is never enough
Re: Fitting Z1000A engine into Z650 frame
MikeSB6 wrote:. The side lugs for the lower engine mounts on the engine are currently preventing lowering the engine any more but I'm not sure about trimming them as it might weaken the mountings.
Cheers, MikeJ
If you are talking about the actual aluminium mounts on the engine then under no circumstances must they be altered.
The original steel engine mounts on the 650 frame need to be removed.
You need some flat plate or bar stock across the lower frame rails with the SUMPLESS engine sat on these to get it level and start working out the position of the new mounts starting with the rear triangles and then the spacers either side to centralize the engine.
It will be much easier if just you use the bare crankcases at this stage rather than lugging the complete lump about.
You will probably end up making more than one set of rear plates before you get the correct position.
You want the engine sat parallel with the frame rails, not canted fore or aft.
Hello Hardcore,
thanks for the information. I'm currently fitting a set of empty cases into the frame and making possible engine plate shapes using cardboard to try to get into the right area. If the engine is level in the frame, will it be possible to remove the cam cover to access the valves for adjustment?
Cheers, MikeJ
Cheers, MikeJ
It's been 30 years and many beers since I built my 6/9 which was very soon sold on for an offer I couldn't refuse but I vaguely recall that it was the head that couldn't be removed without pulling the entire motor first.
Pretty sure the cam cover could be slid backwards off the head after the carbs were removed.
MikeSB6 wrote:Hello,
thanks again for the info. So long as I can get the cam covers off that'll do nicely,
Good luck with whatever you're making at the moment,
Cheers, MikeJ
Speak to MDM (Dave Manning) as he has done this conversion before.
Regards, Will
Users browsing this forum: Google [Bot] and 19 guests
