Front disc tab washers
steve big zed
#1 PostAuthor: steve big zed » Sun Aug 28, 2016 9:42 pm
Hi all, I have new tab washers for the disc bolts but when I torque up the bolts they twist the tab washers any one have any answers thanks steve
#2 PostAuthor: z1bman » Sun Aug 28, 2016 10:26 pm
you can put a smear of grease under the tab washer & on the nut but if they are after market ones they are only half the thickness of the originals & are not fit for the job. if your not worried about originality fit schnorr washers
wheelysteve
#3 PostAuthor: wheelysteve » Mon Sep 05, 2016 7:39 pm
Did you have any luck getting round this Steve?
I've got the same issue but haven't figured a way of not twisting the lock washers. They are the same thickness as the ones I removed ( but are not Kawasaki items).
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
needaz1100r
#4 PostAuthor: needaz1100r » Tue Sep 06, 2016 12:13 pm
wheelysteve wrote:Did you have any luck getting round this Steve?
Have you tried with an air impact wrench? The short sharp shocks may 'knock' the bolt round before the tab washer has chance to snag and be drawn round with it, especially wit a drop of synthetic oil under the head. the actual torque, beyond being tight, isn't too critical.
If you wanted to run the wheel round to Woodley I'd have a go with you if you don't have an impact wrench and compressor.
Mark.
wheelysteve
#5 PostAuthor: wheelysteve » Tue Sep 06, 2016 3:34 pm
I haven't tried the impact wrench.....I'll give that a go.
Thanks for the offer.
Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
needaz1100r
#6 PostAuthor: needaz1100r » Tue Sep 06, 2016 8:29 pm
wheelysteve wrote:I haven't tried the impact wrench.....I'll give that a go.
Steve
No problem, let us know how you get on.
Mark.
wheelysteve
#7 PostAuthor: wheelysteve » Tue Sep 06, 2016 9:53 pm
I seem to have minimised the distortion by taking all the sharp edges from the underside of the bolt heads (new bolts used), and polishing them on my buffing wheel. A bit of oil and gradual tightening and they are tight.
In the Clymer book it states the the torque setting for the disc bolts at 30 foot-pounds which seams high ?
The original Z1 service manual states 140-190 in pounds ( 12 - 16 ft lb ).
Bit of a difference . What's the right figure ?
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
#8 PostAuthor: z1bman » Tue Sep 06, 2016 10:48 pm
16 ft lbs maximum
wheelysteve
#9 PostAuthor: wheelysteve » Wed Sep 07, 2016 7:13 am
Cheers Z1bman :D
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
