exhaust popping
Wayne1960
exhaust popping
#1 PostAuthor: Wayne1960 » Sun Jun 19, 2016 1:53 pm
So started bike this morning and all good but i can tell something still not right. I've carried our all the tests but this is what i find
No 2 exhaust pops and has a heavier thump than all other 3 which feel good.
Exhaust No 2 at the manifold is considerably cooler than all others.
any ideas?
Bike now finished what a joy!
floydsz1
#2 PostAuthor: floydsz1 » Sun Jun 19, 2016 2:05 pm
While it's ticking over pull number 2 plug cap off the plug so it's not clipped on but resting on it. Then lift it off very slightly but still with the plug inside the cap. See if it starts to fire and the pipe gets warm . Once it's run for a minute push it fully back on.
Wayne1960
#3 PostAuthor: Wayne1960 » Sun Jun 19, 2016 8:17 pm
Ok I'll give it a go. What I did do was
Pulled the black nipple cover off the rubber manifold on each carb and all responded except number 2 had no effect at all.
So wound the air screw all the way I an all the way out on no 2 carb and nothing changed.
All other carbs responded.
floydsz1
#4 PostAuthor: floydsz1 » Sun Jun 19, 2016 8:53 pm
Could be a lazy plug. Some of mine often do it. My zrx does it on number 1 if it's stood for a month or so. My z1b does it on number 2 if it's been left for a few days. once the plug has warmed up its fine.
jimmock
#5 PostAuthor: jimmock » Sun Jun 19, 2016 11:27 pm
floydsz1 wrote:Could be a lazy plug. Some of mine often do it. My zrx does it on number 1 if it's stood for a month or so. My z1b does it on number 2 if it's been left for a few days. once the plug has warmed up its fine.
"A lazy plug".
Is that a plug that just lies in bed all day???
Like a "Jeremy Kyle type" spark plug???
Jimmock. :wnkr
I hate people I don't like !
DavidZ1R
#6 PostAuthor: DavidZ1R » Mon Jun 20, 2016 2:45 pm
Had the same thing a week or so ago on my Z1R, swapped plugs around and hey presto, cleared, :D having said that, I have had a few plugs complete failures on my z250, for some reason they just die, when tested they show a short to the main body? NGK originals as well, very strange.
Taffus
#7 PostAuthor: Taffus » Mon Jun 20, 2016 3:21 pm
"A lazy plug".
Jimmock as Plug
(\__/)
(")_(")Image
#8 PostAuthor: ZedHead » Mon Jun 20, 2016 3:52 pm
"A lazy plug".
Admin - this is a direct slur on the shell suit brigade! These are the Britain we are fighting to keep on Thursday :wink:
Wayne1960
#9 PostAuthor: Wayne1960 » Wed Jun 22, 2016 9:24 am
It was the plug! Took it out and it was wet with petrol. Dried it, cleaned it, checked for spark before and nothing but after good.
Put back in and much better!
#10 PostAuthor: warren3200gt » Wed Jun 22, 2016 10:23 am
If I ever have plug problems its always with NGK's. Swopped all bikes to Denso's and plug issues never happen now.
NGK's, even the kosher ones, seem to be going down hill over the past few years. probably driven by the pressure to increase profit by reducing quality.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Wayne1960
#11 PostAuthor: Wayne1960 » Wed Jun 22, 2016 11:46 am
Ok what's the equivalent Denso?
#12 PostAuthor: chrisu » Wed Jun 22, 2016 11:56 am
Wayne1960
#13 PostAuthor: Wayne1960 » Wed Jun 22, 2016 7:52 pm
ok so bike running much better now but still ordered the Denso plugs. hopefully they will come for the weekend.
Wayne1960
#14 PostAuthor: Wayne1960 » Sun Jun 26, 2016 8:55 pm
Den so plugs arrived and installed. Turned all air jets to 1 1/4 turns out and my god what a difference. Went out round the block and unbelievable.
Must have been running on 3 cylinders !!!!!
Thanks all for your support.
Can someone direct to how to upload pictures please?
