I Cannot find where this has been discussed before but i need some info.
I GPZ 1100 B MOTOR And I want to be sure it has the right ignition advance unit.
the T Mrk lines up spot on but i seem to remember reading there were differences in some model advance mechanisms.
How can you tell for sure anybody know the differences?
Also anyone know a reason why a mk11 igniter and pickups would not work on a GPZ11 Motor?
how to identify which model advancer unit you have?
ignition advance
Thought we did this the other day all the B1/2 1000j advancers are the same part no so must advance the same.
The unitrac and R2 are electronicly advanced its just a disc on the unitrac.
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there
GPz 305 project
Re: ignition advance
1962royp wrote:Thought we did this the other day all the B1/2 1000j advancers are the same part no so must advance the same.
bang on. as already said all the 1000's & 1100's are the same the last four digits of the part no are stamped on the advancer base.
if yours has 1020 stamped on the advancer it is the correct one
- spondonges
