Hi,
Any recommendations on where I can get a front paddock stand to lift the front wheel up so I can remove it and remove the fork legs to replace the seals. It seems most front paddock stands are now two short to lift the front wheel and fork legs clear for removal.
Paddock stand front
I use a jack which I bought off bikerstoolbox.  I jack to the frame and this raises the front wheel
http://www.bikerstoolbox.co.uk/acatalog ... IFT05.html
(\__/)
(")_(")
(")_(")
- wheelysteve
				martinz1000r
Taffus wrote:I use a jack which I bought off bikerstoolbox. I jack to the frame and this raises the front wheel
I also have one of these. Highly recommended. The type that goes under the headstock is good on modern bikes but my Z with big wheels and long forks doesn't have enough lift
I also have one of these jacks that sit under the frame.
I increased the height of the 'cups' so I could use it with the exhaust still fitted.
This is what you'll need;
http://www.ebay.co.uk/itm/20mm-Diameter ... 4d1f571148
http://www.ebay.co.uk/itm/M20-20mm-THRE ... 1a037f911c
