Any ideas? My speedo has stopped working. Disconnected it and put a drill on end of cable and the needle registers so it's not the actual speedometer or cable.
Put it back together and made sure it engaged on the pin in the front wheel unit but nothing.
Speedo stopped working
Bike now finished what a joy!
turn the cam in the speedo drive & check if the worm gear is turning? if its not the gear has worn & you will need to replace the complete speedo drive
http://www.ebay.co.uk/itm/Kawasaki-Z900 ... SwdWBXOerv
Ok i have removed the wheel and the speedo drive and clearly something isn't working as it should.
if i turn the cam the worm gear turns but intermittently.
i would really like to keep the init as its original so can i strip it down and if so how?
the pin itself is hardened you would need to drill from the opposite end of the dowel & tap it through & that's if you can get another worm gear. it realy isnt worth the aggro trying to repair
http://www.ebay.com/itm/NOS-OEM-Kawasak ... Cw&vxp=mtr
