Got the bike mot'd on Saturday, went out for a long run yesterday, when I got into traffic, the clutch would not dis-engage. Over the past month I have fitted an ape clutch mushroom, new cable and cleaned and adjusted all clutch components as per factory spec. Any ideas /suggestions would be appreciated.
foz
Clutch drag
Clutch drag
drink feck arse girls
				wilsonsjw11
				wilsonsjw11
the outer cable is compressed when you pull the lever in if the outer cable is made out of inferior steel coil it will compress more than it should when hot but instead of the inner cable pushing the clutch apart you loose some of this leverage due to excess compression of the outer cable. have a look at the cable & see how much it flexes when you pull the lever
						z1bman wrote:the outer cable is compressed when you pull the lever in if the outer cable is made out of inferior steel coil it will compress more than it should when hot but instead of the inner cable pushing the clutch apart you loose some of this leverage due to excess compression of the outer cable. have a look at the cable & see how much it flexes when you pull the lever
Good info ta! This seems to be a common problem on Zeds - I thought it might be the clutch plates expanding when hot, causing them to need more movement of the clutch actuator
