hi all goin to be fitting the vesrah head gasket on my z1a does it fit any way round cos the steel rings are round on both sides but one side looks flatter.
cheers
vesrah head gasket
KeithZ1R wrote:the side with the flats on the copper washers goes down im told ...cue derision
Yep slighty domed copper uppermost!
ogre wrote:might av been a bit premature between my first post and keithz1r reply cos i think i fitted them the other way round i have put a very thin layer of hylomar on both sides cud it be ok or is it a strip and start again.
It's not "end of the world" and should be okay..... just depends how anal you are. Its a gasket and is compressed equally both sides, by similar flat metal surfaces. I'd give it a go and not sweat it
PS: Hope it's not BLUE hylomar, needs to be high heat resistant.
