Torque setting
Niall M.
Torque setting
#1 PostAuthor: Niall M. » Wed May 18, 2016 8:33 pm
Hi All,
Anyone know the torque setting for the sump bolts on a 77 Z1000A1 can't seem to find any ref to it in the manual.
Many Thank's,
Niall.
Niall Mehigan
Hobbo
yo
#2 PostAuthor: Hobbo » Wed May 18, 2016 9:28 pm
22 ft torque lbs
phil
oldzed
#3 PostAuthor: oldzed » Wed May 18, 2016 10:43 pm
Seems awfully high if we are talking about the 6mm threaded bolts.
member number 0664
Who can catch a Kawasaki?
A police helicopter
#4 PostAuthor: z1bman » Wed May 18, 2016 11:07 pm
inch lbs
#5 PostAuthor: PAULJAC47 » Thu May 19, 2016 7:32 am
Just nip em up diagnally using the inbuilt torque setting in your hands,these old friable threads in ally strip easily..
#6 PostAuthor: Pigford » Thu May 19, 2016 11:37 am
Yep - same as cam cover - just "nip them" by hand!
Niall M.
Torque Setting
#7 PostAuthor: Niall M. » Thu May 19, 2016 4:45 pm
Thank's Lad's,
As suggested just nipped them by hand you can feel when you've given them enough.
Thank's Again,
Niall.
Niall Mehigan
RALPHARAMA
#8 PostAuthor: RALPHARAMA » Thu May 19, 2016 5:40 pm
7-8 ft/lbs USE A TORQUE WRENCH!!! I build engines as part of my living and I use one!
Ralph Ferrand
Niall M.
#9 PostAuthor: Niall M. » Thu May 19, 2016 6:08 pm
OK Ralph,Thank's.
Niall.
Niall Mehigan
#10 PostAuthor: Pigford » Thu May 19, 2016 6:25 pm
I'd still do it by hand - thats 3 x different torque figures given above :lol:
RALPHARAMA
#11 PostAuthor: RALPHARAMA » Thu May 19, 2016 10:07 pm
Pigford wrote:I'd still do it by hand - thats 3 x different torque figures given above :lol:
Mine comes from the pukka Kawasaki manual! If more folk used torque wrenches I would get less business fitting helicoils :D
Ralph Ferrand
#12 PostAuthor: z1bman » Thu May 19, 2016 11:05 pm
engine covers do not need to be torqued only if they have a bearing surface between the joining surface. clutch cover / points cover & housing / generator cover/ cam cover/ sump cover can all be tightened by hand the most common part of a z engine that requires heli coiling is the camshaft caps & this is basically down to people not understanding the difference between inch lbs & ft lbs ft lbs would be about ten times the torque of inch lbs so that's why these type of accidents happen
Re: yo
#13 PostAuthor: z1bman » Thu May 19, 2016 11:09 pm
Hobbo wrote:22 ft torque lbs
phil
are all your 6mm bolts stripped :lol: :lol:
RALPHARAMA
#14 PostAuthor: RALPHARAMA » Fri May 20, 2016 6:12 am
The most frequently striped threads on a Zed tend to be the final drive cover because they are over tightened by folk who don't own/use a torque wrench.
You should ALWAYS use a torque wrench on any engine bolts. A torque wrench prevents the overtightening of fasteners. It is not just used on head bolts etc which are torqued down in a specific sequence.
"By hand" is not a torque setting, which is why so many M6 threads get stripped. As someone professionally working on engines, if a casing has a lot of bolts like a sump, I'll whizz them in carefully with a cordless impact wrench on low and then run round with a digital 1/4" torque wrench. Every bolt perfect and done briskly.
Ralph Ferrand
Hobbo
Re: yo
#15 PostAuthor: Hobbo » Fri May 20, 2016 6:31 am
phil
No bud I read it wrong thought he meant oil drain sump plug 😅
Phil
