Clutch
- Fred the Zed
Clutch
Fred the Shed has been laid up a year and now the clutch is very stiff. It was a bit heavy a while ago but now its ridiculous.
Its been away for a rewire and the clutch cover has been off so the starter can be checked. What's the most likely cause of the stiff lever? Can the cover been taken off and not put back correctly cause it?
Or is it just a dry cable and the ramp mechanism needing a spot of grease?
I'm looking to get a PMC Easy-Clutch to make it more pleasant to ride anyway but your advice is sought so I'm not fiddling around all day looking for the cause.
All the best
Fred
All the best
Fred
Paid Up Member
careful with replacement cables cos some of the pattern ones are far too long for a shed and you end up with a sharp 90 degree bend at the bottom that makes it stiff and bind by default take the cable off and look for sharpish kinks if you find one try and straighten it a wee bit, invest in a cable oiler they are pennies and make a huge difference the last bit is ensure the push screw in the casing is clean and free, but far and away the biggest cause is a convoluted cable run....good luck
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- Fred the Zed
Thanks for your advice guys.... in between chores today I've whipped the cover off and found that the cable is frayed around the last 1/2 inch inside the cover.
Initially I thought 'problem solved' but then thoughts I'd better see if the clutch push rod moves.... I slipped a nut spinner / t-bar over the exposed end of the clutch push rod and gave it a hefty push and I can't budge it a mm.
Question - does this mean that the clutch plates are seized up or would you not expect to be able to depress the push rod by hand?
If it is the plates.... how much of a job is it to replace them?
Fred
Fred
Paid Up Member
Pull the rod out and lube,you can see if plates are seperating through oil filler hole,you can sometimes carefully pry apart through oil hole with blunt screwdriver.
- Fred the Zed
- Fred the Zed
z1bman wrote:you would have to have the strength of the incredible hulk to move the push rod the way you are trying to move it . it needs leverage. your problem is probably a dry clutch lifter or the cable
Good advice. I'll change the cable first and see how it goes.
All the best
Fred
Paid Up Member
https://www.z1enterprises.com/product/PM72-230 I think this link will work if it does this is a great piece of kit worth every penny I have bought three now if you also fit a new cable it will feel like a hydraulic clutch.
- Fred the Zed
walshyco wrote:https://www.z1enterprises.com/product/PM72-230 I think this link will work if it does this is a great piece of kit worth every penny I have bought three now if you also fit a new cable it will feel like a hydraulic clutch.![]()
Cheers Walshyco
Thats the exact kit that I was looking at. I was going to order it from Webike in Japan... or Saisei ... or off ebay
Thanks for the tip
Fred
Paid Up Member
Users browsing this forum: Google [Bot] and 16 guests
