Eddie Lawson replica running rough
Stugill
#1 PostAuthor: Stugill » Fri Apr 15, 2016 8:58 pm
As title my 1984 Z1000R2 is running very rough.
If I remove the leads from 2 and/or 3 plug there is no change in the running of the engine.
I have checked the electrics and there is a strong spark from all, including 2 and 3.
I therefore thought it will be fuel. I drained the float bowl on all 4 carbs and then turned it over again, the same thing happened - it started but was rough. Again removing 2 and 3 plugs made no difference. I checked the float bowls and they had fuel in again. I didn't remove the carbs ( as that is a pain ) however I took the tops off and all looked ok, not gummed up etc.
1 and 4 downpipes were really hot ( as you would expect ) 2 and 3 were warm, I could touch them fairly easily.
I hope this makes sense and someone can point me in the right direction.
Stu
floydsz1
#2 PostAuthor: floydsz1 » Fri Apr 15, 2016 9:33 pm
Are the Ht leads going to the correct plugs
Stugill
#3 PostAuthor: Stugill » Sat Apr 16, 2016 7:33 am
They are indeed, bearing in mind it is only firing on 2 cylinders it is a surprise it runs at all.
I might whip the carbs off and give the carbs a clean. The biggest problem is the poxy rubber rubbers.
Stu
floydsz1
#4 PostAuthor: floydsz1 » Sat Apr 16, 2016 7:58 am
As you know cylinder 2 and 3 are on the same electrical circuit so it would seem to me your problem is there somewhere. Try changing the coils over. That would eliminate anything electrical if it's still the same.
Stugill
#5 PostAuthor: Stugill » Sat Apr 16, 2016 12:57 pm
Thanks.
I will have a look at that.
Stu
#6 PostAuthor: PAULJAC47 » Sat Apr 16, 2016 1:42 pm
You say you have a spark on 2 and 3 but is the ignition timing right?
#7 PostAuthor: Pigford » Sat Apr 16, 2016 3:31 pm
Is there 12v getting to the coils.... if its a bit low the spark may not be man-enuff.... I'd at least swap plugs, 1 & 4 ..... with 2 & 3 to be sure :!:
Stugill
#8 PostAuthor: Stugill » Sat Apr 16, 2016 10:41 pm
Thanks for the advice.
I will check the voltage and plugs as soon as I can.
Stu
neilbarrett
#9 PostAuthor: neilbarrett » Sun Apr 17, 2016 7:29 am
dry the plugs then start it with a suirt of easy start ,if it runs on all four then its ya carbs ,if not ignition
Mr Bump
#10 PostAuthor: Mr Bump » Sun Apr 17, 2016 7:55 am
If it's been standing for a while don't forget to change the fuel before you go much further - modern unleaded doesn't store for very long at all before it starts to go off. And the methanol in it sucks up water so yr tank goes rotten. Nice.
Olly
Stugill
#11 PostAuthor: Stugill » Sun Apr 17, 2016 12:47 pm
Thanks.
I will try the easystart. It is new fuel.
Stu
Stugill
#12 PostAuthor: Stugill » Fri May 06, 2016 7:58 pm
I have managed to get out today to have a look at the coils.
I checked resistance for both coils, primary and secondary side whilst off the bike and they were both within the parameters.
I then put them back on and started it up again and same rough running.
If I remove the leads for 2 and 3 the there is no discernible engine change.
I then disconnected the wires for the r/h/s coil which runs 2 and 3 and there was also no change.
I swapped the wiring over and the bike would not start at all.
I had an old coil for the bike so I checked the resistance on this one and it was fine so I tried this on the r/h/s and the same thing happened - zero.
I ran out of time and I propose to check the wiring as I think this is the issue.
Any other thoughts? or have I messed something glaring.
Stugill
More thoughts needed please
#13 PostAuthor: Stugill » Sun May 08, 2016 6:10 pm
I have checked the wiring for breaks and all good there.
If the Ac igniter is faulty will it fail totally or could it work to one coil?
Is it worth just getting a new set of coils? If yes, Dyna's?, I think I need the green ones? and best place to get them?
Stu
tlc
International Rep
#14 PostAuthor: tlc » Sun May 08, 2016 7:17 pm
I would try swapping the ic igniter then the pick ups.
Mine worked sort of but had begun to break down.
Asphalt Cowboy
Stugill
#15 PostAuthor: Stugill » Sun May 08, 2016 8:23 pm
Cheers.
I will look into that.
Stu
