debben1 wrote:Hello Teddy, interesting project
 We can supply all the head gaskets from 1015cc to 1500cc from stock, with 1200cc you have a choice of copper or CFM20 wich is a fibre type compound. The CFM20 has excellent sealing properties but will be limited on how much boost/compression it can handle, the copper gasket can handle more cylinder pressure but does not have the excellent oil sealing properties of the cfm20 gasket, you may find the top of the cylinder block has been "O ringed" with steel wire, if so then you should only use these wire inserts with a copper gasket. Gascacinch is a gasket sealant that works well with the copper gaskets, cfm20 gaskets should be used without anything. Regards, Steve.
Hi debben1. When i get back home from work i will try and get some things done with the engine, and then i will find out what 's hiding in there....
 . And it's good to know that you can supply head gaskets in various dimensions. I might have to order one from you when needed.
From what i could see outside the engine it looks like a copper gasket fitted.
Well from the comments i guess i have to say that i have left the normal side in this world.
Even if my wife saying that i'm everything else but normal.......
Pasc, good luck with your support group, you may get a new member soon..
