Needle jet install
Needle jet install
Guyz, just fitting a set of needle jets to some a4 carbs,seem a bit tight to push new ones in even when carbs heated,dont want to force as know the brass in quite soft,pushed the old ones out with with hard wood dowl,was thinking of making a shoulderd pastic or wood dowel to fit new ones?
Steve, gonna go with freezing the jets overnight,warming up the bodies in the oven and making a shouldered drift out of plastic or hardwood..Paul
Made a drift out of piece of dowel,turned to fit hole in jet with shoulder to press jet in,good tip about the chamfer,froze jets overnight in tub with wd40,all fitted ok..
