Spark Plug Threads !
				thezfactor
Has anybody come across this problem before ? All four spark plug threads on my Z900 cylinder head are pretty much shot, no problem I hear you shout. I've got a Helicoil kit to correct the problem. Now here's the rub, it turns out that one of the holes has already got an insert in it !  I've taken the loose insert out, and the insert tap is a very pissy fit (engineering term) in the hole, no metal has been cut but a new insert inserted, and the result is the same "unusable". The Helicoil tap cannot be any bigger as it is just about to touch the valve seats now !
						Sounds like a nightmare.
									Jimmock.
I hate people I don't like !
loctite the helicoil then use a thread chaser to clean the helicoil
http://www.ebay.co.uk/itm/like/19124417 ... ue&ff13=80
spark plug threads
I had this with my B2
Take to an engine builders he will put a steel insert in. back to std
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there
						GPz 305 project
- z1000puddin
I had one like this in my A1 Thou head
Big sert is a next stage up time sert
http://www.timesert.com/html/bigsert.html
Zed til Dead
				thezfactor
[/img][/url]
As you can see here the helicoil insert was touching the valve seats.
So I have decided to tap the hole out 3/8 bspt and make a special plug to fit.
The downside is I will have to do all four cylinders.
And I will fit 10mm spark plugs.
Here is one of the four off plugs that have been made, complete with a hex drive to be inserted into the head.
Plug fitted.
Spot faced off to achieve a flat face.
A bit more dressing off still to be done.
There you go job done x 4.
