750 ltd carb confusion
stevie g
#1 PostAuthor: stevie g » Tue Feb 02, 2016 7:57 pm
Hi Guys, Can anyone give me a little info regarding what carbs should be on a 750 ltd. the carbs are mikuni CVs yet when I go on the net for the specs they all say Keihin, how come ? Thanks to all replies, $tevie.
stephen g mackay
#2 PostAuthor: z1bman » Tue Feb 02, 2016 8:17 pm
that's because they where fitted with 34mm Keihin's
stevie g
#3 PostAuthor: stevie g » Tue Feb 02, 2016 8:23 pm
Hmmm, Ok thanks. Mine has Mikuni round slide CVs. Do you know if they were fitted with the same carbs as the Zephyr 750 ?
stephen g mackay
#4 PostAuthor: z1bman » Tue Feb 02, 2016 8:38 pm
yes but smaller on the zephyr 32mm
stevie g
#5 PostAuthor: stevie g » Tue Feb 02, 2016 9:00 pm
The reason I'm asking all this is, I'm gonna build a 750 engine for my Zephyr which has an early GPZ lump in it at the moment. Gonna use a ZR7 bottom end which has the primary chain tensioner, gpz ut 750 barrels, head and cams, z550, gpz 550 or zeph 550 six speed gearbox and maybe skim the head a little. Been doing some research and it seems the 34 mm mikunis are pretty well suited to that setup if you can't get 29 mm smoothbores or the likes. Would love FCRs but too dear. So the previous owner of the ltd must have fitted these mikunis at some point. The ltd is I broke some time ago BTW.
stephen g mackay
#6 PostAuthor: z1bman » Tue Feb 02, 2016 9:15 pm
the carbs you want are the mikuni's that where fitted to the gpz750r1
stevie g
#7 PostAuthor: stevie g » Tue Feb 02, 2016 9:33 pm
Ah, OK thanks. Wonder if the carbs I already have are from that model ? any idea how I would know ? stamps etc ?
stephen g mackay
#8 PostAuthor: z1bman » Tue Feb 02, 2016 9:44 pm
the 750 r1 carbs are black & the carb tops have a crinkly type finish
stevie g
#9 PostAuthor: stevie g » Tue Feb 02, 2016 9:49 pm
Really ? that's brilliant news cos that's exactly what I have. Thanks Z1bman. really appreciate your knowledge, Yeehaw. $tevie.
stephen g mackay
#10 PostAuthor: z1bman » Tue Feb 02, 2016 9:58 pm
should be mikuni 36mm
stevie g
#11 PostAuthor: stevie g » Tue Feb 02, 2016 10:04 pm
OK I'll measure them up tomorrow, cheers $
stephen g mackay
jimmock
#12 PostAuthor: jimmock » Tue Feb 02, 2016 10:26 pm
This is why I love it on here!!
This carb talk gets me all fuelled up. :oops:
Jimmock. :wnkr
I hate people I don't like !
stevie g
#13 PostAuthor: stevie g » Thu Feb 04, 2016 6:59 pm
Spoke too soon. they're 34s. Bummer. Anyone out there with a set of 36s ?
stephen g mackay
steve.w
#14 PostAuthor: steve.w » Fri Feb 05, 2016 7:52 am
all gpz 750 inc 750 unitrac ran the bst 34mm mikuni carbs as did the 1000 etc but slightly different never heard of 36mm mikunis on a gpz as standard ..34 is the ones fro the job :wink:
#15 PostAuthor: z1bman » Fri Feb 05, 2016 9:01 am
steve.w wrote:all gpz 750 inc 750 unitrac ran the bst 34mm mikuni carbs as did the 1000 etc but slightly different never heard of 36mm mikunis on a gpz as standard ..34 is the ones fro the job :wink:
http://www.motorcyclespecs.co.za/model/ ... p%2082.htm
