UNLIMITED LTD - The Pigford Project
#91 PostAuthor: Pigford » Sat Jan 30, 2016 5:22 pm
Done a few bitz here & there.
Fitted the alloy engine mountings (cheers Padders)...
Carbs stripped & cleaned... 28mm Miks with K&N twin filters...
Also the grab rail (thanx Gary) and some winkers (rare items for me)...
Still got to tackle the wiring - gonna start that tomorrow :??
#92 PostAuthor: Pigford » Sun Jan 31, 2016 12:43 pm
First time she's ran for a long time !!!!!
Carb's need some sorting (leaking a bit - jetting's out too) and rest of wiring sorted, but it's getting there.
https://youtu.be/3GgNepwBoQg
Don't think it'll ready in time for the ACE Cafe though :evil:
#93 PostAuthor: Pigford » Wed Feb 03, 2016 5:27 pm
Thanx to my quick reactions - and Padders, I now had a mint set of RS34's stuck on me Harris....
...... which replace the loverly VM28 carbs which I got from Adrian H a while back (off a GS1000?) but are now going to be used on my Z1000 LTD :twisted:
RALPHARAMA
#94 PostAuthor: RALPHARAMA » Wed Feb 03, 2016 6:15 pm
Can we now assume tharris isn't been punted on? Defo right carbs for the bike :D
Ralph Ferrand
#95 PostAuthor: Pigford » Wed Feb 03, 2016 8:11 pm
vduk wrote:Can we now assume tharris isn't been punted on? Defo right carbs for the bike :D
Ralphy - you is correct old bean... gone past that dodgy area and decided I'll hang on to the Harris for the moment. It's great only having 4 x bikes to step around... so I can get stuck into me bikes "as and when".
Looking forward to the S.W Rally 2016 - that's my realistic aim for this project :twisted:
Is Vic There
#96 PostAuthor: Is Vic There » Thu Feb 04, 2016 3:14 am
Can you let me know what cables you use, better still before you get them can I talk to you, I need cables for my Harris and it would be good if you could get a set made up for me when you do it!
#97 PostAuthor: Pigford » Thu Feb 04, 2016 7:08 am
WIRING :shock:
TBH, you probably don't wanna copy my efforts. :oops:
1] My Harris is already finished - I did it a couple of years back.
2] It defo is NOT the neatest arrangement :lol:
3] I got several different colours from VWP (Vehicle Wiring Products) and just did it.
Most of the modern wires take higher loads than the original stuff. I also solder all connections (spades, butts, bullets, etc).
There are some photo's way back in Projects Section somewhere.... I'll dig them out later today :wink:
Is Vic There
#98 PostAuthor: Is Vic There » Thu Feb 04, 2016 10:02 am
I'm on about the throttle cable mate :lol:
#99 PostAuthor: Pigford » Thu Feb 04, 2016 1:21 pm
:oops: T'was your daft accent that confused me :roll:
I'm using an R1 throttle assembly....... but the inner was a bit long on the push side. So I got a universal set off Venhill and cobbled a new Pusher. Came with various nipples (snigger). There was a little blob of solder one end and it had a small nipple that fits the throttle end.... so I just had to cut it to length (Dremel with disc ) then at the carb end I used a screw-tight nipple to fit :wink:
I never have much luch soldering - probably coz they're s/s cables!
Photo's later
Is Vic There
#100 PostAuthor: Is Vic There » Thu Feb 04, 2016 7:21 pm
Nice one, interested in the bend at the carb side!
#101 PostAuthor: Pigford » Thu Feb 04, 2016 8:35 pm
Now the RS34's are on me Harris..... I fitted the VM28's (GS1000?) on the Z1000 - and she runs real sweet (apart from the blowing zorst) :twisted:
https://youtu.be/8AiNn3RUyHg
Just need to finish the rest of the wiring now :cloud
Coose
#102 PostAuthor: Coose » Thu Feb 04, 2016 8:51 pm
That swinging arm is so ridiculous it's fantastic! :D
#103 PostAuthor: Pigford » Fri Feb 05, 2016 7:21 am
Coose wrote:That swinging arm is so ridiculous it's fantastic! :D
It's been stashed away for so long - I just had to use it :lol:
#104 PostAuthor: Pigford » Thu Feb 25, 2016 7:06 pm
Got me nice Marshall, glycerine filled oil pressure gauge from the USA...
.... gotta be worth another 5 mph :twisted:
#105 PostAuthor: Ginger Bear » Thu Feb 25, 2016 7:13 pm
Yeah.......... Slower, when you look down and it's reading zilch. :eek :eek
# 104
Users browsing this forum: Bing [Bot] and 13 guests
