Hi all, what is the alternative bolt that people use to remove the rotor?
Cheers Rob
Z1000j rotor removal
I welded an impact socket on the end of a rear wheel spindle with no nut. To remove the rotor i attach the tool to an electric impact gun (from Clarkes tools a 400watt beast designed to remove wheel nuts, about £50) press the tighten button and off comes the rotor , I can lend the tool I made but would recommend buying the impact gun, they are brilliant - does the clutch nut too, best tool I own!
Managed to get the rotor off with the bolt I ordered, although it was one of the hardest I have done. One of the bolts on the clutch had sheared and the others were loose. I have ordered replacements and will use a stronger loctite on them, hopefully this will stop them coming undone again.
Rob
Rob
