ST Reincarnation
ollie wrote:Looking good Adam ,but please get shot of that gold on the legs![]()
Cheers Ollie, in time, it'll stay for now because I am painting everything myself and Winter is no good for painting in a cold garage. Shame everything was bloody gold cos the quality of the paint is ok. Hopefully have them in black by the Summer.
1979 Z1000ST
Desperate Stan
- Regular Poster
Slow progress even for me but after assessing the calipers I thought it best to go the whole hog and do them properly as opposed to just painting them to tone down the green. With rebuild kits, pads and now brake pad plates adding up to the best part of £100 I thought sod it let's try and strip the paint myself. So armed with a flat screwdriver and some Nitromors (new formula is shite so don't bother) I stripped them down to bare metal.
At this stage I was considering a single disc set up
I may yet leave them bare metal to match the rear but in the meantime I have finished both and ordered everything to rebuild them.
Once they are done I only have to get the headlight on and lights wired up and it should be ready to go. I started it up the other week with the new tank on and it started up ok after sitting idle for a few months. Rode it into the garage and had forgot to bleed the rear brake after putting it back together. Stopped it just before making a zed shaped hole in the garage wall. Knob!
1979 Z1000ST
Hi Adam , i bought some of this paint stripper about 12 months ago having got pissed off with the new nitromors .
This is proper eye watering , smelly , burn like a bastard when you get it on your skin stuff .
It also removes paint just like old nitromors used to .
http://www.ebay.co.uk/itm/Starchem-Pain ... SwzgRWt7F0
0172 . Geoff Parr
Z1parR wrote:Hi Adam , i bought some of this paint stripper about 12 months ago having got pissed off with the new nitromors .
+1 on that stuff........ Positively evil.
I finished the calipers and they are back on the bike. Just need to connect them up and bleed them. The rebuild kits were from powerhouse via ebay and were spot on (next day, free delivery) and contained all except the small O-rings (x4 per caliper). The ones I had already were in fine condition so were reused. The pad holders were from zpower. The Clymer is useless for this task, it suggests taking them to your local Kawasaki dealer but it isn't too tricky apart from getting the dust seal on. A bit of Red Rubber Grease made the job easier.
And one of both bikes. Not far to go now..
1979 Z1000ST
ollie wrote::wink: good work Adam ,i also got some of that industrial paint stripper ,its just like the old type nitromors or worse ....lol![]()
had a good laugh at the zed shape hole in the garage![]()
Cheers Ollie, it was a close one. I will get some of that paint stripper for when I get round to the forks later in the year.
1979 Z1000ST
Managed a bit of time this weekend to get the brakes filled and bled and the headlight back on and wired up. There was a bit of daylight left to wheel her outside and take some pics. Couple of small jobs to do like paint a few bits on the engine and side panels to paint but this is pretty much done for now. Also want to get the stand extended a tad so it doesn't lean so much!
1979 Z1000ST
Users browsing this forum: Bing [Bot] and 12 guests
