I imported a KZ650 as a donor when I restored my UK B1 and ended up using very little of it. As a consequence I have a near complete bike to build a crazy project with. Currently working on the engine so have some time to source some modernish toys for it. Plan is to buy a shitter that has USD forks and monoshock so that I can nick the bits I need from it and out the rest as parts.
The swing arm is a period z900 dresda box section with additional bracing and monoshock mounts to be added.
Wheels are period 3 spoke CMA z900
The 650 frame is going to get chopped about A LOT (Trellis exo skeleton) so not too worried about hacking it to fit.
Question is does anyone know which shitter to buy so that there isn't to much engineering involved in utilising the existing 650 frame head stock and swing arm mounts.
I believe the head stock and swing are mounts are the same as a Z900
z650 modern take USD forks/Monoshock
- warren3200gt
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
If the swinger width is the same as Z900/1000 @ 235mm then Most Suzuki stuff will fit in there. GSXR600/750 SRAD, TL1000, Bandit & probably more recent Suzuki too. Kawasaki stuff ZX9R, ZX7R is too wide to fit without major work. Also check the forks for pitting from any 'shitter' that you might buy.
- warren3200gt
Thanks, GB. I'm not to concerned about the swinger mounts as the DRESDA box I have fits. What I'm not sure about is the head stock. So I'm looking for a USD fork model where they will drop straight into the existing headstock if poss. Would also need to be Mono shock model so I can nick the shock, mounts and links etc. ZX6R? Zx7R?
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Modern stems are normally thicker than a std Zed stem. You may be able to do some bearing swopping to achieve the desired end result. www.simplybearings.co.uk is a good place to start.
Failing that, chop the yokes from a Zed stem;
Turn down the leftovers of the yoke to the correct i.d. of your new yoke.
- warren3200gt
- warren3200gt
Found this which may help. Spose it depends on the stem length.
www.allballsracing.com/index.php/forkconversion
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
LeeJackson
I built a 650 special many moons ago, I used FZR 400 front and back end, it was very easy, yokes were a straight fit with a swap in the head races (as per the all balls site mentioned) and the swingarm drops in with the exception of having to add twinshock mounts and I think a 6mm spacer either side.. I'll see if I can find some photos somewhere..
- warren3200gt
Hi Lee, didn't think any fzr's had usd forks though?
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
LeeJackson
LeeJackson
Found some photos here incase your interested..
http://www.turbomotorcycles.org/TMIOA/P ... ckson.html
This was it pretty much finished when I stuck the Turbo in it.. Still have it actually, stashed somewhere in Scotland to be revisited some day...
