Z1R carbs
Its been a weekend of setting up amongst other things, a bit of a roller coaster as usual but today sounding good. Will let you know tomorrow the progress after a ride. Went out on Saturday for a test ride, salt down so hose down after, pulls good and strong, although a vast improvement and now ticks over just not good enough at light throttle just yet. Took some photos as it was sunny, some guy in a range rover stopped to take alook, he wanted to buy it, not surprised as it looks stunning with all fittings and stuff being new. will try and remember how to post pics on here if anyone would like to see it.
Have put some photos on photobucket and hopefully the links will work.
http://i1166.photobucket.com/albums/q60 ... grug1x.jpg
http://i1166.photobucket.com/albums/q60 ... 51l6xc.jpg
http://i1166.photobucket.com/albums/q60 ... jv60jv.jpg
Not sure how to make them visible in the post. Anyone?
Thanks for that Ginger bear, it has had atttention to detail, lots of cash spent on so many new parts by previous owner/owners, it needed the carbs sorting maybe thats why they moved it on i dont know. I have spent time running through all possibles with it and now realise carb no 3 it not fuelling low down, fitted a set of good Z900 carbs as a temp measure to check, and it ran sweet low down pulling from 20mph in top. going to sonic clean that carb although i cannot find a problem with it, if that fails i will be looking for Z1R carbs or better still 30mm or 32mm as the ports have been taken out to that.
garyd. the number plate came with the bike, going to get a proper one soon.
