KZ750 engine number chart
Hi guys, Does anyone have a link to Z750 4 cylinder engine numbers till I see what I have ? I'm fitting one into a Zephyr 750. I had to cut out the rear mounts and re-weld them slightly further apart. Not much in it, think it was 15 mm of a difference. On the front I turned one of the frame mounts round the other way and put spacers at the other side. Also changed the pickups and rotor, carb intakes to take zeph carbs and that's about it really. Thanks to all replies, $tevie.
stephen g mackay
