Headlight Bulb
- wheelysteve
- wheelysteve
Got some of these from Eurocarparts. Half price plus extra 10% off so worth a punt. Might go down the relay route to get max benefit.
Anybody know what size fuse/cable is required for the bulb supply if using a relay ??
Cheers, Steve
http://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_847
For 10% off, use code EXTRA10
Cheers, Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
						1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
- RALPHARAMA
H7's are no use on a Zed. You need H4.
You can use 1mm² for the switch side and 2mm² for the load side.
Ralph Ferrand
- wheelysteve
- wheelysteve
Serps wrote:A 10 amp fuse will do as the bulb will draw 5 amps.
W/V = A 60/12=5
As Ralph says the issue is more with the old Zed wiring looms. The cable thickness's he has suggested are more than adequate also use thin wall.
http://www.vehicle-wiring-products.eu/p ... sq-28-0-30
