Z800 Cafe Chopper Fighter thing...
Royalratch
#286 PostAuthor: Royalratch » Sun May 03, 2015 12:10 pm
Crofty wrote:
Royalratch wrote:any +12V lines must be fully insulted from the body
What do you say to insult it Ratch? :lol: :lol:
Lol.
I get it now - I did want to use the frame as earth and minimise the cable runs as by earthing locally to loads but I'm pretty sure someone said bikes aren't run like this - as cars are.
Here's where I'm at. The main supply feed to the Motogadget is probably too thick - but fused top the correct amps. In theory I could do away with that earth bar then...
HowieD
#287 PostAuthor: HowieD » Wed Jul 01, 2015 8:43 am
Royalratch wrote:I did want to use the frame as earth and minimise the cable runs as by earthing locally to loads but I'm pretty sure someone said bikes aren't run like this - as cars are.
I have done "Local Earthing" on the previous Horace loom and doing it this time too - it works fine.
CD185, Maggot, Z1-R, Horace
j.wilson
#288 PostAuthor: j.wilson » Wed Jul 01, 2015 9:02 am
Looking really good and tidy-
just like a shop-bought one! :wink:
z650/1400 bonneville hybrid.
Is Vic There
#289 PostAuthor: Is Vic There » Wed Jul 22, 2015 9:46 am
Looking at making a wiring harness for my Harris, how do you rate the moto gadget gear? Have you found it easy to work with?
Royalratch
#290 PostAuthor: Royalratch » Thu Jul 30, 2015 3:25 pm
The whole reason MotoGadget gear exists is ease of installation with modern spec electronics and the ability to hide everything.
But even I was doing a full on rest I'd use their stuff as the guts.
Can't say enough good things about them...
Bps
#291 PostAuthor: Bps » Fri Aug 07, 2015 12:35 am
I have Motorgadget on my bike - been on since 2013 when I got bike Sept last year I have put on 2200 miles all running without a single hitch
Is Vic There
#292 PostAuthor: Is Vic There » Fri Aug 07, 2015 1:19 am
Re the motogadget swipe ignition, I assume that you swipe it once for on then swipe it once for off, or does the sensor need to be close to the pick up all the time?
Royalratch
#293 PostAuthor: Royalratch » Fri Sep 25, 2015 10:21 am
No its as you describe.
HowieD
#294 PostAuthor: HowieD » Fri Oct 23, 2015 4:04 pm
Is Vic There wrote:Looking at making a wiring harness for my Harris, how do you rate the moto gadget gear? Have you found it easy to work with?
It's simple as a simple thing to work with. I have built Horace with a full set of their gear with problems at all. They provide a simple wiring loom diagram and you can buy a kit of wiring materials which matches it all.
Royalratch
#295 PostAuthor: Royalratch » Wed Nov 11, 2015 10:09 am
Hello lads.
Getting the project ready for a final assembly :D and setting up the head tube preload. The machinist who made my yokes also included these 2 different preload rings.
I assume the bigger one screws down and sets the preload and the top one is the lock ring?
My question in short is - are both supposed to stay on there? There does appear to be space for both under the top yoke.
HowieD
#296 PostAuthor: HowieD » Thu Nov 12, 2015 3:40 pm
Is Vic There wrote:Re the motogadget swipe ignition, I assume that you swipe it once for on then swipe it once for off, or does the sensor need to be close to the pick up all the time?
I have my sensor mounted on the inside of the seat and the Key Fob has to touch the Seat right on top of the Sensor (but other side of the fiberglass) to work.
Royalratch
#297 PostAuthor: Royalratch » Thu Nov 12, 2015 3:58 pm
But then the seat is hardwired to the bike - makes removal trickier? I mounted mine on a bracket inside the side panel facing out. So I swipe right over the 'Z750' emblem :jake
HowieD
#298 PostAuthor: HowieD » Thu Nov 12, 2015 4:10 pm
Is Vic There wrote:But then the seat is hardwired to the bike - makes removal trickier? I mounted mine on a bracket inside the side panel facing out. So I swipe right over the 'Z750' emblem :jake
Erm nope - wired into a loom and multi-pin plugs - if the plug isn't connected the ign dosen't come on.
Royalratch
#299 PostAuthor: Royalratch » Thu Nov 12, 2015 4:57 pm
Yup - figured.
Any thought on my head tube setup lol???
#300 PostAuthor: zed1015 » Thu Nov 12, 2015 11:06 pm
Royalratch wrote: Any thought on my head tube setup lol???
Usually one stem adjuster nut on older stuff followed by the top yoke which sits tight on top to prevent it from moving when the stem bolt's done up but a lot of modern bikes use two especially when there's no pinch bolt on the top yoke.
Either way will do as long as the top of the stem doesn't protrude so far that it prevents the top nut or bolt bottoming out before it tightens on the top yoke.
I notice there is no bearing dust cap fitted in the pic so don't forget that before fitting the nut/s too.
