Cam timeing
RALPHARAMA
#16 PostAuthor: RALPHARAMA » Tue Nov 10, 2015 2:05 pm
Pigford wrote:I did have a 180 shim - but lent it out a few years back and not seen it since :evil:
If tips of valves need trimming - I believe its a max of 0.3mm
Piggy you are spot on the money :D
If you still are too tight then you'll have to have new seat fitted :shock: This must only be performed by a really good engineer, as a bodger could write off the head and they are no longer plentiful!
Ralph Ferrand
relisysxx
#17 PostAuthor: relisysxx » Tue Nov 10, 2015 6:42 pm
Thanks guys, going to pick up a 200 shim at the weekend so we can go through them and see what's what. If they are too tight it'll be off with it's head! (only put the bleeder on last week)
#18 PostAuthor: chrisu » Tue Nov 10, 2015 6:55 pm
do a compression test straight after - i'm hoping you haven't bent any valves...
