Headlight Bulb
wheelysteve
Headlight Bulb
#1 PostAuthor: wheelysteve » Mon Nov 09, 2015 8:42 pm
What is the best H4 (wattage) headlight bulb to fit on a UK spec Z1B without overloading the 40yr old standard electrics?
Cheers Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
wheelysteve
#2 PostAuthor: wheelysteve » Wed Nov 11, 2015 10:35 pm
Nobody out there :cry:
The original bulb is like a candle. Is there anything better that won't melt stuff ?
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
jimmock
#3 PostAuthor: jimmock » Wed Nov 11, 2015 10:55 pm
I'm here!!
Jimmock. :wnkr
I hate people I don't like !
SVENLEATHER
#4 PostAuthor: SVENLEATHER » Wed Nov 11, 2015 11:03 pm
Steve let me know when you find out. Came back the other evening and could not tell if the blinking light was on or not. It was only who I saw that slight glow on the car in front at the traffic lights. I'm sure a modern day push bike light kicks out more power.
mick znone
#5 PostAuthor: mick znone » Thu Nov 12, 2015 7:45 am
found this on a quick search, may find a lot more on a longer one
http://z1ownersclub.co.uk/forum/viewtop ... mp+upgrade
scott
Junior Section leader
#6 PostAuthor: scott » Thu Nov 12, 2015 7:57 am
If its standard bulb in there then just leave it on high beam all the time....it might reach 10 watts :lol: No one ever flashed me when I used to leave mine on
#7 PostAuthor: PAULJAC47 » Thu Nov 12, 2015 8:24 am
Use the original wiring to switch a relay which is fed from a higher rated fuse ,wiring and is capable of handling the extra current,you can then safely fit high output lamps.
Hinckley
#8 PostAuthor: Hinckley » Thu Nov 12, 2015 11:09 am
Osram 'Night breaker unlimited' are standard fit H4 bulbs - extra output without using more amps.
Halfrauds etc...
As Paul says - the standard 40 year old wiring/switches can be used to operate a relay - micro relays from auto electrical supplies would fit inside the headlamp shell.
http://www.autoelectricsupplies.co.uk/p ... tegory/194
z-fever do a clear 7" headlamp which I am toying with using.
http://www.z-fever.de/ShopNeu/shop/popu ... boscnicsk7
Non original appearance could be a deal breaker!
#9 PostAuthor: ZedHead » Thu Nov 12, 2015 11:31 am
LED ones are available ... No idea what they're like?
Kev1R
#10 PostAuthor: Kev1R » Thu Nov 12, 2015 12:45 pm
Could be the reflective 'silvering' on the back of the headlight, which does deteriorate over time, rather than the bulb - In which case a new light unit could be the easy answer
Worth checking anyhow.
010
RALPHARAMA
#11 PostAuthor: RALPHARAMA » Thu Nov 12, 2015 1:38 pm
The standard H4 fitment is 55/60watt, which will work fine on your bike providing the wiring's not shagged. If the wiring is knacked then a new loom is not a huge investment from Z Power and they also sell pattern switches. Whilst the switches aren't as good quality as the OEM ones, they are loads better than a shagged out stocker!
I think that the wiring on most Zeds is getting beyond it's sell by date these days and I have rewired dozens of them now. I wouldn't say I can actually do 'em with my eyes shuts, but I'm getting there :D
Ralph Ferrand
markz9
headlight
#12 PostAuthor: markz9 » Thu Nov 12, 2015 2:03 pm
Might be worth trying to get hold of a new cibie headlight unit they did a direct fitment and its so much better than the original
I will have a look on mine to see if there is a reference number
Mark
wheelysteve
#13 PostAuthor: wheelysteve » Thu Nov 12, 2015 5:03 pm
Thanks for the replies, i'll look into some of these.
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
jimmock
#14 PostAuthor: jimmock » Thu Nov 12, 2015 7:08 pm
FFS Guyz,
The Guy was looking for help.
NOBODY answered him, and now he has 300 replies!!!
Jimmock. :wnkr
#15 PostAuthor: Garry.L » Thu Nov 12, 2015 9:04 pm
These are a good upgrade over standard......
