Z1R carbs
Z1R carbs
Hi can anyone help here to identify the differrence between Z1000 A1 carbs and Z1R carbs from the outside or code number. i know if i took them off i could measure them as Z1000 are 26mm and Z1R are 28mm. Just bought a Z1000 and on the list of bills it says Z1R carbs have been fitted, any ideas please?
Carbs off now to check the pilots as too rich low down, they are 28mm Z1R and thank you for your help with the identifying. The pilots are 15 but are new, maybe from a repair kit which i have been told by a guy who knows, that these kits are good for the gaskets but to throw away the jets as they are rubbish, if so i need to find origional 15 pilots for these carbs. Anyone have any to sell or advice to give would be appreciated thanks.
						Update, i now find receipts from Debben performance that this engine was fitted with 389 performance cams, adjustable sprockets and bigger stailess valves with the ports and seats cut and blended, WOW what a bonus. Took the cam cover off and the cams ae marked Made in USA, CWC with a 22 in an oval circle and EF14 or maybe EP14 markings. Measuring the lobes they are 28mm side and 37mm tall forgetting the points bit. Valve clearance are set to 6 thou spot on. Later today i find out it is a Z1R engine in a Z1000 frame, should have spotted the D in the engine number i guess. I love these little surprises, enjoy the research but any help on what cams they might be and carb base settings, even cam timings would be appreciated, the sprockets are set to midway and the lobes are horizontal at TDC as they should be. Used to have a GS with fancy cams etc and that was fun to play with but now got a beutiful bike to play with, when the carbs are back on and sorted i will take a pic of it and share it if you like. Thanks for any advice or help in getting me there would be appreciated.
