Spacers
Spacers
Will be fitting standard swinging arm soon but was wanting to check the correct set up for the front sprocket and wheel spacers. At the moment I have no spacer fitted to the inside of front sprocket is this correct for z1b and what would be the standard size for the rear wheel spacers ?
I find it very difficult to believe that no one on here dosent know the correct set up (spacers) for front sprocket and rear wheel maybe just can't be arsed replying 😀 The problem I have is a non standard swinging arm which I am changing for a standard item but to get the non standard item to work all spacers have been messed about with so any help with this will be greatly appreciated
What are you looking for - length of spacers x external diameter.
Standard swing arm just has dust covers / caps to each end.
If you go to the downloads page on the link, there is a downloads page which has Z1B parts list, which will give you part numbers for rear wheel spacers - http://classickawasaki.se/
Brake side spacer / collar - Kawasaki part no 42032-037.
http://www.ebay.com/itm/1973-77-kawasak ... 95&vxp=mtr
Sprocket side spacer / collar - Kawasaki part no 42037-023
http://www.ebay.co.uk/itm/75-Kawasaki-Z ... 4ad11bf30f
I can measure a rear brake spacer if you wish, I may have a spare ?
Not sure if I can measure the sprocket as the spacer sits partially within oil seal.
- wheelysteve
I've got completely standard Z1b's and the drive sprocket is fitted without a spacer but one side has a raised boss which goes on the transmission side, thus spacing it out slightly.
The rear sprocket has a spacer behind it, approx 1.5mm thick.
This is using standard 630 o ring chains.
This shows the side to fit to the gearbox]
This is the spacer behind the rear sprocket
Hope this helps, Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
Thanks my front sprocket doesn't have a raised boss the chain just misses the casing I'm using a 630 chain does I have seen 1.5mm spacers on z1 enterprises site my rear sprocket has the spacer as described once I have removed the swinging arm and fitted original item I think I might just need to sort front sprocket out thanks for replies.
