Rear wheel offset
GinjaDave
Rear wheel offset
#1 PostAuthor: GinjaDave » Tue Sep 22, 2015 12:20 pm
Does any one know the wheel offset, from hub to rim, on a rear spoke wheel, off of a Z1000 A1? I striped it down to put new spokes in and didn't take the measurement first :oops:
Of all the things I've lost I miss my mind the most
#2 PostAuthor: warren3200gt » Tue Sep 22, 2015 1:22 pm
Not sure it helps but on a 650 its 12mm from hub edge (drum side) to rim edge.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
flateddie
wheel offset
#3 PostAuthor: flateddie » Tue Sep 22, 2015 3:31 pm
Got my z1000A1 spokes hanging up in the garage waiting to be overhauled have a measure up on Saturday for you.
THEMACCLADS
#4 PostAuthor: THEMACCLADS » Wed Sep 23, 2015 3:36 pm
Sprocket side 28.2mm
Disc side 28.6mm
Hope this helps. Paul
Beer and Sex and ChipsNGravy - It's all a Macc Lad needs.
flateddie
z1000A1 offset
#5 PostAuthor: flateddie » Fri Sep 25, 2015 8:29 pm
Hi There,
Just measured my A1 spoked wheel with the sprocket carrier out mine is 29.5mm from the hub to rim.
good luck
Eddie
GinjaDave
#6 PostAuthor: GinjaDave » Mon Sep 28, 2015 5:45 pm
Thank you very much gentlemen that's very helpful.
Regards Dave
wayno
#7 PostAuthor: wayno » Tue Sep 29, 2015 6:44 am
Out of curiosity is there an offset on the z900's a4?
