Sparking Points !
Sparking Points !
Hi Guy's, am I correct in saying my condensers could be Duff if I'm getting sparking at the points
Only problem is they where probably fitted about 2 years ago, but done very little miles in that time. I do intend fitting an electronic ignition at some time but I'm desperate to make it run well as it should, first with original points. Am I mad
or just stupid
wilsonsjw11
Full bundle with leads £290.44 and freeshipping using code FREESHIP0815
http://www.saisei-europe.com/Shop/Produ ... kawasaki-z
Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
kev edwards wrote:Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
Kev, I've got a 4 into 1 original Z1R
johny brando
phil1r wrote:kev edwards wrote:Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
I'm sure the Dyna system is good & I've a CDi MK11 ignition system on my 900 kawa & yeh there both reliable I'm sure......... BUT- hey, with points & condensors you'll always get home if it goe's tits up on you at the side of the road & you can buy alot of points & condensors for 295 sobs. O yeh , I guess your aware that points do normally spark ... but when they really start arcing quite brightly ....yeh there toast & you can test em quickly & easy enough you'll find the simple tests in the manual.
Mmmm, I guess you could always have the best of both world too & carry your spare points plate assy under your seat...just in case ! Cheers Johny Brando.
johny brando wrote:phil1r wrote:kev edwards wrote:Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
Fitted new condensers, still the same
Dyna S
Before I fit the Dyna S. I'm still having a go to make it run 95% on points, as said before changed condensers with no difference. I have a feeling 2-3 coil may be a problem, but not a obvious fault. So put a brand new set of Denso plugs in AGAIN
2nd set in a week. I managed to ride it for a few miles not good though, but better than before. Got back looked at plugs again, number 2 wet but header pipe warm
. Changed the plug cap on 2 ran slightly better
So I've purchased a cheap coil with leads to replace 2-3. But my problem is where to put the wires, one is black and the other is black with white line. So anyone know
- Mark Tiller
