#5 PostAuthor: tlc » Mon Aug 24, 2015 7:15 am
			Chris.
I'm gonna recommend the Yammy XJR swinger. It will take wider wheels easily, is 1" longer than the Zed and has twin shock mounts already fitted. These mean either you space out your top mounts to suit or move in the bottom ones if you need.
It needs about 6mm shaving from each side of the pivot to suit the Zed frame and a sleeve to marry the standard Zed spindle to the XJR bearing sleeve.
Rear axle size is good too for using Zed hubs.
									Asphalt Cowboy
